Are Block Quotes possible in The Bat?
The title pretty much says it. For some reason, a search for "block quotes" turns up nothing. Help appreciated.
using 4.2.10
That could mean several things. If you want to paste a block in quoted format, use Paste Quoted (Shift-Alt-INS). If you want to indent a quoted block, select it in column mode and press Ctrl-K I. If you want to center a block, select it and press Alt-C.
Or, if you mean a quote style where the quoted text is indented and preceeded by a single " sign, I'm afraid that's not an option.
Edited: Daniel van Rooijen - 05 May 2017 13:16:20
Thanks, Daniel. Appreciated.
using 4.2.10
