Here is a slightly quirky idea for a helpful improvement.
FIrst, I notice that if you have many Virtual Mailboxes, it can take awhile for them to populate after the reboot.
And I think there is a "holdover" flag .. "Store State between Sessions" but I have not seen it work, and I think I always have it checked yes. (This is an interesting question, if our readers can share their experiences on this, much appreciated. If I can get the holdover to work, the rest of this suggestion becomes not so consequential.)
Beyond that, probably the best way to keep the time lag down (this also applies to the length of time of searches) is to avoid "Text" and "Message Source" and even "Headers" as the fields used. Try to use Sender, Recipient and Subject -- the scanning will be 100 times quicker. However, that is not always applicable, because often you would like to see also any reference in text to the item or person being searched.
Let us say you reboot, and there is a Virtual Folder lag ... maybe an hour or more to completion. (I tend to reboot once or twice a day, just for crisper response time.)
We know how easy, and helpful, it is to make a Virtual Folder out of a Search. Use it all the time. In those lag periods, the reverse would be superb. Make a search out of a Virtual Folder, automatically, without recreating line by line.
Your thoughts?
Your thoughts?
