migrate mailbox files from Bat 6.4 to 9.0
Is simple move mailbox files from old computer with bat 6.4 to new computer with bat 9.0 possible or some conversion is needed?
I think you can just copy the contents of your old mail folder to the (new, empty) mail folder on the new computer.
At some point in The Bat's history, the message base format has been changed but I don't recall if that was before or after v6.4. Either way, the conversion was done automatically by The Bat itself.
The Bat support EML and MSG format so first you can export The Bat 6.0 mailbox in EML/MSG format. After that, you can import into Tha Bat 9.0 using import export option
I prefer in such situations to do backup and then restore to the new installation.
https://www.ritlabs.com/en/support/help/71/#6641
https://www.ritlabs.com/en/support/help/71/#6644
