Hello,
sorry, it is very hard to explain this as I am not a native english speaker. I have the following themplate set up
Hello!
Thank you for your interest in the Zhengdu Screenreader Youth $v edition.
This message contains confidential information. Please keep it safe, as losing or disclosing the data contained in it will result in losing all your obtained rights.
Authorization code: $code
Authorization password: $password
Purchased edition: $edition
Activation deadline: $deadlinedate
The basic method of activation is outlined below. Shall you have any problems please contact the Zhengdu Screenreader support team by either directly replying to this message or creating a new one.
1. Please download the latest version of the program from the following link. The below source is official and safe, but before executing the installer please check its safety using an antivirus software. Warning, do not use Windows defender!
$url
2. Extract the downloaded archive.
3. Execute the installer and follow its instructions in order to install the software.
4. If you have decided that you do not want to start Zhengdu Screenreader right after installation or the installer asked you to reboot, press CTRL+ALT+I to start the program now.
5. In the window that pops up, write your authorization key and password in the edit boxes and press "OK" in order to connect to the program's server and download the activation.
We wish you a great success in using the screenreader and remind you kindly that in case of any problems we are for your complete disposal.
With best regards,
Arkadiusz Swietnicki, Zhengdu Screenreader Support Agent.
Zhengdu ID: 138003
For now I replace the variables manually buyt I wonder if there is a way to create a template which would generate a kind of a form for me to input values in.
I can use the PHP script to send such E-Mails, but more people need to handle that and hence I askedabou The Bat! template.
Hello!
$url
With best regards,
Zhengdu ID: 138003
