Does TB! have its own interface when adding an attachment? It's very bland with none of the favourites or shortcuts as found on Windows Explorer. Is it possible to tell TB! to use explorer instead?
Here my ALT+PgUP interface with icons:
Is this you want?
— Официальный дистрибьютор The Bat! в России |
Yes, that would be better. I can't find the button for adding a screen shot of what I have...
Thank you for your replies. The bottom line is that I can't change the file explorer for Windows Explorer which was what I was asking.
Cheers. |
