The bat hang with IMAP Folders processing
This issue is a bug that I know for about more then 5 years.
When I close my mail client, for some reason, the client still hangs when you close it with the dialog box 'Processing IMAP folders' in the queue.
There is no time out for this or it looks like you can not disable that 'maintenance'  feature.
I wonder if there might be a connection with this topic?
How large is your CONFIG.CDB file? (by default, it is located in C:\Users\UserName\AppData\Roaming\The Bat!)
It should not be larger than some 50 KB. If it is larger, it may be corrupt. In that case, try this:
- Exit The Bat
- Rename CONFIG.CDB to CONFIG-CDB.OLD (or some such name)
- Relaunch The Bat
The Bat will now make a new CONFIG.CDB with default values and hopefully that will work without problems.
Note: CONFIG.CDB contains settings for system hotkeys, viewing modes and message list tabs, and maybe some other settings. You can make a note of those settings beforehand (or screendumps), or restore the file afterwards (when The Bat is not running) to restore the old situation.
Excuse me joining an old thread
I have the same hanging on exit problem with IMAP processing using Voyager, I presume that the Voyager equivalent config file is CONFIG.EDB, mine was 100KB in size?
Renaming CONFIG.EDB to force the creation of  a new CONFIG.EDB, produces a new 32KB sized file but Voyager still hangs on exit while compacting the  folder
"user"@outlook.com\Sync Issues\Server Failures
Do you have any suggestions as to what should I try next?
Uncheck in the settings of a box this setting -
https://www.screencast.com/t/E0KjADRhcXDI
(compact folder after each message deletion).
Then check options of box and uncheck "compact all folders on exit"
