Default is set to Plain text. Does not work. I try to switch to Plain text (Ctrl+1), does not work. Anyone here from developers? Anyone can confirm????
Are you mean as this ?
— Официальный дистрибьютор The Bat! в России |
In my Preferences, Viewer/Editor, Default text format of the Message Editor is set to Plain. Also, for every account, all template format is set to use Plain editor...
Edited: - 22 June 2022 17:05:36
What strange is that in the editor, there is no check mark beside the Plain text if I go Options, Message format after Ctrl + N for example. Do you have a checkmark there? Stupid forum software cannot even insert a photo here. Is the year 2005 or 2022???? I was a distributor for Ritlabs for many years, I never thought they go this low in customer support |
