Does TheBat! support MAPI? Can I use it to connect to MS Exchange Server to read my corporate emails (IMAP is not allowed on the server)?
Strange.. it used to be supported, but at..:
....it says that MAPI was removed from the 'New Account' dialog. I think that means that you can no longer make a new MAPI account (but I'm not sure.. maybe there is a work around.. It may be best if you ask Ritlabs directly by sending them an email, or through the Support option in the menu above (this is just a user-to-user forum)).
Why don't you contact Ritlabs support like I suggested? They'll have the answer.
Because I hoped that perhaps this is known now. Anyway, I sent the ticket. Will let you know.
