i had a v9, then installed v11 in parallel. After some time trying it, i bought a key for the new one and installed the latest version.
I removed the v9 via Windows.
But still, when i start Windows, the startup loads an older version of The Bat! ( v11.0.4.1) instead of the latest one. (v11.2.2)
I have to close the older one and manually start the newer.
The v11.2.2 has the following link: "C:\Program Files\The Bat!\TBLauncher64.exe"
The v.11.0.4.1 in the startup menu: "C:\Users\***\AppData\Local\The Bat!\Main\11.0.4.1\64\TheBat64.exe"
In the Windows Application list i see only this: "The Bat! v.11.0.3.2 (64 bit)"
It's a total mess!
How can i solve that?
Or how can i change at least the startup menu to start the latest version?
Thx!
It's a total mess!
Thx!
