Huge Size of "Trash" dir in spite of it is empty
I have just noted that I have enormous files in programfiles/thebat
The Trash is 400 000 ko  and another that i created, spam folder is 740 000 ko
However, i have cleaned theses repertories so there is ni more mail and yet, the size of the files in dir of the bat doesn't change...  Is it normal ?  Can i delete those big files, will there be reconstructed ?
Thanks a lot,
Telepro
PS :  The bat 2.12
That's because TB doesn't really delete the messages you tell it to delete (or move), they're merely marked as deleted. All databases and mail clients work this way. That is because editing big (and a message base is a big file) files takes lots of time. TB really deletes the messages when it compresses the message base. You can do this automatically:
Account -> Properties -> Options -> Compress all folders on exit
This makes closing TB somewhat slower, but saves space and makes TB less prone to errors.
ok, thanks a lot   :D
I compressed the two one, I won 1.2 GO   !!!
Thanks
Best regards,
Telepro
