The Bat Voyager synchronization, Activation issue
I'd like to use The Bat! Voyager, but I have a problem with the activation procedure.
I can activate it on my C: drive or my USB drive, no problem.  But what I want to do is use it on my C: drive and be able to just copy the entire Voyager directory to my USB drive.  The problem is, when I try to run it on the USB drive after syncing the folder, the activation is not valid.
Please advise, thank you!
The activation is volume dependent. That is to say it uses the volume name for its activation.
You'd best only copy the MAIL directory (and contents of course) to the USB stick (and back)
This somewhat defeats the purpose of having Voyager in the first place.  I'd really like to be able to just copy my (encrypted) email setup anywhere I want to and be able to use it.  My Bat folders are almost 400 megabytes, and all but the most expensive USB drives are just too slow to run it when I need to search all of my emails for something.  Tieing Voyager activation to the USB drive makes it very inconvenient.
Also, I'd be curious to know when/if I will hit a wall with activations.  How many times can I activate it on a new volume before it tells me no?
Maybe I am going about this the wrong way.
I can already encrypt a volume in my USB drive with TrueCrypt or any number of other encryption tools.  Would it be possible for me to just mirror my The Bat! Pro folder(s) and use them from the USB drive in a pinch?  Or does The Bat! Pro require a formal installation to work?
Thanks.
I use the Bat! PRO with eToken on the laptop and the Voyager on USB-Flash.
Both are encrypting "on the fly".
I really like that product! :)
I think using the Voyager on the regular machine is kind of wrong idea...
winXP-SP3 Pro, the Bat! v4.0.38
Is there a faster way to synchronize between The Bat Pro and Voyager than using the multi-step synchronization tool?
It would be ideal for me if Voyager could simply import my The Bat! mail from my main drive right from the main files, without me having to do anything in The Bat pro.
Did you try to Backup on one installation and then do a Restore on another?
Yes.  That is how I get it going.  However, that process is still time consuming and since Voyager is just a different build of The Bat, it would be logical that it should be able to simply import The Bat message folders from my hard drive without me needing to go through a backup process.
I don't mean to sound like a complainer.  I actually think The Bat! is the best email client available and I love using it.  I'm just trying to find the simplest, fastest way to "back up" my mail to my flash drive on a routine basis.
If I could run the backup process from the command line, that would be helpful -- then I could schedule a backup overnight.  But it doesn't look like there is a command line option for backing up.
You can schedule a backup with TB's scheduler, that's how I'm doing my weekly backup for TB pro.
No.
I'm having TBV to leave my messages on the server and BCC all outgoing mail to myself, so that I'm getting a copy on my TB pro config for every message.
TBpro needs a formal installation to work. What you could do is to use a TBpro and TBV with the same password. Then you could copy the message base to your USB stick for TBV to read if it's really necessary.
Thanks for all the tips!
I am absolutely delighted by TBV, and very grateful to Ritlabs for making it available for no charge - now that's good customer service!
What I would really like to be able to do is to synchronize just the inbox of each of my accounts, without any subfolders within the inbox.  Is this possible?  The backup/restore method described above does everything, and I've not managed to get the sync method to work properly - and doesn't that also do everything?
So my ideal would be a selective synchronization - I hope someone will tell me this is possible from within TB or TBV, and if not, then that there is some clever workaround that will do the trick.
Thanks in advance for any help you might give...
helinlin20171028michael kors outlet clearance
yeezy boost 350
ugg sale
coach outlet online
coach purses
canada goose jackets
red bottom heels
uggs outlet
coach outlet online
kate spade handbags
moncler sale
cheap ugg boots
cheap jordan shoes
moncler coats
harden shoes
polo ralph lauren outlet online
yeezy boost
michael kors
adidas store
uggs outlet
canada goose
ugg outlet store
canada goose clothing
michael kors outlet canada
nike air max 2018
tory burch shoes
canada goose sale
birkenstock shoes
adidas sneakers
canada goose coats
uggs outlet
coach outlet store online clearance
adidas yeezy boost
salvatore ferragamo shoes
mlb jerseys whgolesale
ugg outlet
the north face outlet
michael kors uk
coach factory outlet online
moncler
pandora jewelry
kate spade handbags
longchamp outlet
oakley sunglasses outlet
canada goose sale
pandora charms outlet
ferragamo outlet
uggs clearance
uggs
uggs outlet
canada goose outlet online
the north face jackets
coach outlet online
nike outlet store
michael kors
canada goose jacket
ray ban sunglasses discount
uggs on sale
polo ralph lauren
ray ban sunglasses sale
cheap air jordans
ugg boots clearance
uggs outlet
mbt
north face outlet
michael kors outlet online
adidas outlet store
louis vuitton outlet store
ugg boots outlet
cheap ugg boots
louis vuitton handbags
ugg outlet online
tory burch outlet online
adidas yeezy shoes
adidas superstars
michael kors handbags outlet
uggs outlet
michael kors outlet store
coach outlet online
cheap jordan shoes
ralph lauren sale
canada goose coats
ralph lauren sale
coach outlet online
ugg outlet online
birkin handbags
polo ralph lauren
coach outlet store
coach outlet online
uggs clearance
ugg boots
cheap ugg boots
burberry outlet
pandora charms sale clearance
retro 11
pandora charms
coach outlet online
ugg outlet
coach outlet online
michael kors bags
yeezy shoes
canada goose outlet
moncler coats
ugg boots
coach factorty outlet online
cheap air jordans
air max
canada goose outlet
moncler coats
longchamp bags
north face jackets
coach outlet online
discount oakley sunglasses
moncler pas cher
ugg outlet store
ugg boots
adidas nmd r1
adidas ultra boost
ugg boots
adidas nmd r1
adidas yeezy boost
ugg boots
cheap jordans
red bottom
caterpillar boots
pandora charms
bottes ugg
ugg boots
hermes outlet
kate spade outlet
christian louboutin sale
pandora charms sale
adidas nmd runner
uggs outlet
ralph lauren
canada goose
uggs outlet
longchamp sale
ugg outlet
fred perry shirts
cheap nfl jerseys wholesale
nike outlet store online
ray bans
yeezy boost 350
yeezy shoes
burberry outlet online
adidas outlet store
canada goose sale
cheap jordan shoes
canada goose sale
canada goose sale
coach outlet online
air jordan shoes
mbt
ugg outlet
toms outlet
canada goose coats
uggs outlet
coach outlet online
coach outlet online
toms shoes
moncler outlet online
timberland outlet
ray ban glasses
adidas outlet online
adidas nmd runner
fitflops sale clearance
cheap oakley sunglasses
canada goose outlet
ugg boots
kate spade outlet online
ugg sale
burberry handbags
uggs
uggs outlet
ugg australia
ugg boots women
coach outlet store
moncler uk
nike huarache shoes
gucci outlet online
ugg outlet store
toms
pandora charms
air jordans
moncler sale
north face outlet
louis vuitton outlet online
moncler coats
ray ban sunglasses outlet
cheap jordans free shipping
pandora outlet
uggs clearance
nike outlet online
coach outlet online
ray ban sunglasses cheap
ugg boots
ugg boots
moncler jackets
toms
coach outlet online
uggs outlet
supreme shirts
kate spade outlet
pandora jewelry outlet
canada goose coats
columbia sportswear outlet
supreme uk
uggs outlet
ferragamo shoes
nike cortez classic
ugg boots clearance
hermens
ugg slippers
burberry handbags
ugg boots
coach outlet online
cheap nfl jerseys
uggs outlet
ugg boots outlet
coach outlet canada
canada goose uk
cheap nike shoes
adidas superstar shoes
canada goose parka
cheap uggs
louis vuitton factory outlet
nike shoes
coach handbags outlet
ugg sale
uggs outlet
christian louboutin shoes
salvatore ferragamo outlet
ugg outlet online
ugg boots sale
coach outlet canada
coach outlet online
uggs outlet online
ralph lauren uk
michael kors bags
gucci outlet
ugg boots sale
uggs outlet
ugg shoes
mulberry uk
cheap ugg sale
timberland outlet store
ugg boots on sale
polo outlet online
nike outlet
uggs
adidas yeezy boost 350
ralph lauren sale
adidas shoes
canada goose outlet
nike sneakers
ugg boots
cheap jordan shoes
ralph lauren sale clearance uk
hermes bag
nfl jerseys
jerseys cheap
michael kors
pandora uk
nike shoes
north face jackets
nike outlet store
coach outlet online
coach outlet online
valentino
jordan shoes
nmd adidas
fitflop sandals
hermes bags
ugg sale
hermes bags
ugg boots
canada goose sale
birkenstock outlet
uggs clearance
mulberry handbags
ugg boots outlet
air jordans
yeezy boost 350
coach outlet online
nike sneakers
ugg boots
canada goose outlet
cheap uggs
cheap ugg boots
canada goose coats
uggs sale
birkenstock uk
fred perry polo shirts
mlb jerseys
ugg canada
birkenstock
cheap ugg boots
pandora charms
ugg outlet
pandora jewelry
cheap ray ban sunglasses
ray bans
louboutin outlet
uggs outlet
longchamp outlet store
ugg outlet
canada goose coats
coach outlet online
mulberry
ugg canada
ugg australia outlet
coach outlet
ugg on sale
michael kors
canada goose jacket
coach outlet online
louboutin outlet
red bottoms
ugg boots
uggs outlet
canada goose outlet
ralph lauren
moncler jackets
ralph lauren outlet
ray bans
louboutin shoes
ugg outlet
discount ray ban sunglasses
coach outlet online
moncler
cheap uggs
moncler jackets
harden vol 1
pandora
cheap jordan shoes
valentino outlet
coach outlet store
coach outlet online
uggs outlet
nike outlet online
toms
cheap jordans for sale
ralph lauren outlet
coach outlet store
mulberry outlet uk
canada goose uk
moncler sale
burberry handbags
north face sale
ray ban glasses
cheap ray bans
kate spade handbags
ugg boots outlet
mlb jerseys
ugg outlet
air jordan retro
yeezy shoes
air max shoes
canada goose outlet
hermes handbags
supreme clothing
toms
jordans
cheap ugg boots
ugg boots outlet
longchamp bags
ralph lauren outlet
moncler jacket
canada goose sale
pandora jewelry store
uggs outlet
cheap air jordans
longchamps
ugg
adidas nmd r1
air max
helinlin20171028
