Hi there,
Everytime I run The Bat! and let it checks emails, it always pop-up a message that says:
"Unknown CA Certificate
The server didn't provide a root certificate during the session, and there is no corresponding root certificate in your address book.
This connection may not be secure. Please contact your server administrator.
Continue anyway?
OK - Cancel"
In the connection status in the Bat! it says: DATE, TIME: FETCH: TLS handshake failure. Invalid server certificate. (The issuer of this certificate was not found...)
And it's going on like that for each account, it's so annoying!
Then I open my address book and see nothing there. I have to open it using the menu. But I can't close the Bat! either! It always says: "Some task are running...". I have to terminate it by task manager.
Later, I run it and the same problems happen again and again!
This problem just appear a few days ago. Therefor, I used The Bat! just fine! Please help help help and help!
Thank you so much!
Sincerely yours
Saigonian
Continue anyway?
OK - Cancel"
Thank you so much!
Sincerely yours
Saigonian
