A few questions from a new user, Colors; Unused(?) folders
It appears that I can assign a color group to just about every folder except for the account name folder.  Is that correct?
I have about 15 accounts and am trying to free up vertical space in the acct pane. There is a mysterious folder named Inbox-Known in every account. Can't find anything in Help about it.  I assume the programmers put it there as an easy target for users to filter to.  I'd like to delete them; will anything break if I do?
Every acct has a trash folder too. It appears from looking at Properties/Mail Management/Deletion that I could set up a common Trash folder and have all acct trash go to it, thereby allowing me to delete all the acct Trash folders.  Correct?
Thanks very much.
Bob
You can delete the Inbox-Known, to do that you need to deactivate the <Known> filter first. Afterwartds you shoul;d be able to delete the Inbox-Known.
This used to work in v2, never tried it with v3.
Idon't know whether it's possible to delete the account Trash folders, but I wouldn't bet on it.
Inbox-Known can be removed.  Thanks for pointing out the filter to remove.  You're right, Trash can't be removed; I didn't notice that when right clicking on a Trash folder 'Delete Folder' is greyed out. Thanks.
