Pages: 1 2 Next
Importing Outlook Mail, Need help importing Outlook pst
I tried the Mailbox Import Wizard to import my Outlook messages from Outlook 2003.  I chose "Microsoft Outlook" and get error message: "Cannot find MS Outlook components to perform import"
My "pst" files (3 in total - 2 pst files are archives" are located in the following Folder:
D:\Data\Outlook
I then figured that The Bat! is only checking for the pst files in the default directory into which Outlook i originally installed the pst files, so I copied the 3 files to:
C:\Documents & Settings\User\Local Settings\Application Data\Microsoft\Outlook
However, once again, I got the same error.
Can anyone help me to import my Outlook data?
I am not sure which Outlook versions are supported, but The Bat! uses Otlook API for import, so if You have PST files only and Outlook is not installed, import can not be done.
I have Outlook 2003 installed and working. But the The Bat! import still doesn't work.
I recently installed Wordperfect Mail and had no problem importing all the Outlook messages.  I am not happy with Wordperfect Mail and this is why I am migrating to The Bat!
Unfortunately, The Bat! has no way to import from Wordperfect Mail - which only exports files in Mbox format.  Unless you have an idea of how it can be done.  I have been downloading all mail to both Outlook and Wordperfect Mail, so both programs have all my messages.
Do I understand correctly and WordPErfect Mail exports to mbox format? Then I don't see the problem, mbox format is also known as Unix Mailboxformat. So when you export to this with WPMail, put the extension .mbx on the files and import it with The Bat!
OK, I exported from WordPerfect Mail in .mbox format.
I then first tried to import as Unix Mail, but "0" messages were imported.  Then I renamed the file to .mbx
The file could not be imported as a Unix file (obviously).  So the only choice I had was to use the Import Wizard.  But what e-mail format do I choose the Import Wizard to import.  The Import Wizard specifies various e-mail programs but doesn't give the option to import an .mbx file.
By the way, thanks for your help so far.
Damn, it should work like this but unfortunately Mbox format is not always the same :(
http://en.wikipedia.org/wiki/Mbox
You could try with the Wizard set to Eudora but I really have no clue what to do exactly now. Sorry.
Perhaps someone else here can help you :(
I tried Eudora - no luck!
Try this for mbx files
http://www.processtext.com/abcpoco.html
This is the link to the Poco Mail converter (mbx files) but there are others
DL a demo and see if it will do it - if not nothing lost.
Hi Ervin,
I use Aid4Mail and can highly recommend it for dragging email from one client to another.  In fact, it's done the conversion you seek for me (Outlook 2003 to Bat!, and back) a couple of times already.  You'd be hard pressed to name a client I haven't dragged mail to/from using Aid4Mail.  It's operation/function is flawless!
It's not free .. but, if you play with different clients, it just might be a worthwhile investment for you.
Good luck.
hey guyz, it is too late but I found by googling Mail Passport Pro - All in one mail converter. It can convert Apple Mail database, entourage archive 2004/2008 (RGE files), Thunderbird/Postbox database, MBOX files, EML files to outlook pst file.
here is the link http://www.mailpassportpro.com
Thanking you
Hello Dear, you can also try IBID Info MBOX to Outlook Converter which is easily import you’re the Bat .mbox files into Outlook PST format. Software also find your .mbox/.mbox files in your computer Hard Drive.
Try third party MBOX to PST conversion tool you can instantly convert Apple mail mbox file to MS Outlook pst file successfully. To know more about and free download click here http://mboxtopsttools.blogspot.com
You can try “MBOX Converter” for both Mac & Windows which not only converts MBOX to PST but also to EML, MSG & NSF formats with the
Naming convention, Multiple views for doing email analysis, etc. with no limitation of MBOX file size and more than 20 email clients support.
Download the free trail:   http://www.mboxpst.com/
Safe MBOX Conversion
It is difficult to convert .mbox mails to Outlook.I have tried several ways and finally gave up the ides for manual conversion.Later i opted for a safest Tool for MBOX to Outlook. I would be glad to share a Converter that I have been using from past 2 years and I am really satisfied. There is no harm giving it a try.
I hope you will like it as well
Edited: Sandra Diaz - 07 September 2016 11:27:41
PST EXTRACTOR PRO is a universal migration tool which convert your Outlook Mail (PST) to Apple Mail/ Mozilla Thunderbird/ Postbox/ MBOX/ RGE / EML file format. So you can convert your pst files in to the format you like to use.
For more visit at: http://www.uslsoftware.com/pst-to-mbox-converter-for-mac/
MBOX to PST Converter is the safest and the strongest tool to export the multiple MBOX files into PST file format easily in few seconds without any loss. It is a multi-featured application which can easily resolves all the issues related to the migration process. This application can easily support to any MBOX file created by any MBOX based email client.
Use the popular MBOX to PST email exporter to export MBOX mailboxes to PST format in easy go. All through the conversion mode software easily retains actual data format (headers, images, attachment files, etc). So get the MBOX to PST email exporter to completely export MDOX data to Outlook profile.
I think you want to import The Bat! Exported file or MBOX file into Outlook email application, but Outlook email application can not import MBOX file directly. To access MBOX file data into Outlook email client you need to convert MBOX file to PST format.  Try this link to complete solution of MBOX file to PST conversion: https://gallery.technet.microsoft.com/DataHelp-MBOX-to-PST-16ae8d1e
Edited: Venn Torrence - 23 February 2017 13:29:36
You can use PST Converter to import outlook data file (.pst) to The Bat!. It’s a complete application that import Outlook files to MBOX format with all the related email headers, formatting and attachments, which you can easily access in The Bat!, Thunderbird, Mac Mail, Entourage and many other email apps. What’s more, you don’t even need Outlook to be installed in your machine for carrying out the conversion process.
Get this All-Rounder PST Converter tool to convert Outlook PST files to MBOX, PDF, EML, EMLX, MSG, vCard and ICS.
Edited: Jessica Smith - 22 March 2017 10:44:28
Use Mail Passport Lite an easy to use migration tool which convert MBOX to PST file format for Windows Outlook. It also convert EML files along MBOX which make this a 2 in 1 converter for your migration. It convert mails, contacts, calendars, attachmentr, etc.
For more: http://www.mailpassportlite.com
This thread seems to have morphed from Outlook -> TBB into TBB -> Outlook.
I have a situation similar to OP's. I have Outlook 2003 and a bunch of PST files. Office 2003 isn't officially supported under Win 10, and we're thinking of taking this opportunity to move that user from Outlook to TB! (I've been on TB! since I moved from PMMail :) at the same time they move to Win 10.
Office 2003 does install on Win 10 but I'm not confident about its functionality (get Error 1019 related to ODBC). Without opening those PST files in Outlook 2003 (and potentially doing who knows what damage), is there a way to get them into TBB? I used Aid4Mail to go PMMail->TBB years ago, but I don't see PST-TBB listed as an option.
Alternatively, has anyone had any success installing the current Outlook (paying the $10 for a month) and then importing into TBB?
Any suggestions will be appreciated, but it's already a hard sell to convince this person they need to pay for an email client, I'll have trouble getting agreement to pay for conversion software on top.
Thanks!
=aw
I have used Aid4Mail with no regrets.
http://www.aid4mail.com
Does the best for bulk migration.
Of course depending on the number of users: Use a local IMAP mailserver to transfer between clients.
This of course requires manual time for each enduser and can not be automated. Outlook -> Exchange/Bat Post or IMAP server -> The Bat!
Thanks, that's very helpful. I asked Aid4Mail and of course they don't support TBB as an output format. Am I understanding that I would use Aid4Mail to convert Outlook PST to "IMAP Accounts" [from the Aid4Mail list of formats]? We've been using Outlook as POP3, would this force us to change to IMAP for The Bat?
=aw
Use aid4mail to convert Outlook PST to mbx. Then use the bat import wizard against the mbx
the other option was to setup your own internal IMAP server and use that from Outlook to The Bat.
another utility that has been used in past IMAPsize which has a feature of syncing (copy) mbx to an IMAP server. Has many features with the bonus of being freeware
After struggling several hours, I have found this program MBOX to PST Converteras a final solution.
software supports 17 MBOX email clients like Thunderbird, Entourage, Spicebird, Pocomail, AppleMail, Eudora............
Pages: 1 2 Next
