Problem sending email
Dear all,
We don't know how to further proceed. Sending mails works one out of ten times.
Here the logfile of a successfull attempt, please note the delay
between 14:49:13 and 14:49:13
Code
[14:49:13]  C: Connected to smtp.rediffmailpro.com, port 25
[14:49:13]  S: 220 pro-237-180.rediffmailpro.com ESMTP
[14:49:28]  C: EHLO dell
[14:49:28]  S: 250-pro-237-180.rediffmailpro.com
[14:49:28]  S: 250-PIPELINING
[14:49:28]  S: 250 8BITMIME
[14:49:28]  C: MAIL FROM:<ajit@auroville.org.in>
[14:49:28]  S: 250 ok
Here the logfile of an unsuccessfull attempt, the same delay.
Code
[14:55:18]  C: Connected to smtp.rediffmailpro.com, port 25
[14:55:18]  S: 220 pro-237-184.rediffmailpro.com ESMTP
[14:55:33]  C: EHLO dell
[14:55:33]  S: !!! Socket error: #10054 (0x00002746) An existing connection was forcibly closed by the remote host
[14:55:33]  C: HELO [0.0.0.0]
To send a message it takes up to 10 attempts, but it does go out then.
The Bat version 4.0.28.3
Sending works without a flaw using another mailclient (thunderbird).
Any idea of what we can do to make it work, can we send you further information to assist in troubleshooting?
All the best,
Ajit
You're using an old beta version.
The official distribution system for betas advise that you use the tbbeta mailing list to discuss (and be notified of) problems with beta versions.
Did you try whether the problem still exists with the current release?
This forum is not intended to discuss problems with betas, that would confuse the users of public releases. Betas are because of their experimental nature, so the most common method of curing a problem with a beta version is up- or downgrading.
Nevertheless, the most likely cause of your problem would be something with a firewall.
