New bug in 4.1 - layout is not saved
Since upgrading to 4.1 I noticed that every time I open The Bat it resets the layout of the panes. It seems to go back to default, with the folders pane taking up half the width of the window.
I have never had this problem and no have no report from users, what OS do You have?
Windows XP Pro x64. It started after doing the upgrade.
It has randomly stopped doing it today. I'll see if it stays that way. No idea what causes/fixes it.
Okay, it's doing it again.
I think I have discovered the conditions under which this happens.
If I close The Bat normally, reboot and try to open it again, the bug happens and the layout resets. If the machine crashes with The Bat open, I reboot and then load it again, the bug does not happen.
