Some Questions: Portability, PGP, TLS, Voyager
Sorry for these questions but I am new and found no answers for the following questions:
1.) Is The Bat portable? Can I e.g. install it on a USB stick and run it on several computers?
2.) Does TB support PGP encryption?
3.) Does TB support TLS transfers to mailservers? Implicite or explicite?
4.) What is the diff between TB Pro and TB Voyager?
Thank you
Matt
Voyager is the portable version of theBat.
theBat itself is also sort of portable, as you may install it once and then copy the installation folder & mail folder to a usb stick, maybe together with the exported registry key
HKEY_CURRENT_USER\Software\RIT\The Bat!\ - but this requires some tweaks to work so using Voyager is easier.
2,3 - yes
